Hi I've got a 53 plate 172 cup with cc which until friday was running fine apart from a weak battery that has now been replaced. My wife drove to work on friday morning, just a couple of miles, and when she went to drive home it would start.
The car turns over but doesn't fire so I the AA who has been out and spent 2hrs trying to fix/diagnose to fault. We have tried a TDC sensor, checked the fuel pump is priming and running when cranking engine, checked for spark at coil pack, removed and cleaned relays, checked fuses, checked injectors.
The out come was the fuel pump is priming and appears to be running when engine is cranking, the coil pack is fine, but the injectors are NOT switching so there is no fuel going in. There is also a orange light on the dash the electronics light I believe.
Any help/advice/suggestions would be very much appreciated. :banghead:
