Strange wurring noise (drivetrain) HELP!!!!
Just changed my tryes from front to rear because of the tread and since i changed it theres a wurring noise from over 30mph up to 60 and then gets quieter.
Going along at 40take it out of gear - Still the same
Going along at 40 turn engine off - Still the same
Changing into to highest gear in 40 - Still the same (does not follow same rhythm as engine rpm)
all tyre pressure set to 32psi - Still the same
the outer nearside cv joint is on its way out but that was the same before this started
anyone got any ideas at all would appreciate it
if the cv joint was on its way out it could just be getting worse, once all the grease has melted out fo them they will just make noise like death then you will be fooked
I would put a bit more pressure in fronts on a Cup, whay tires you fitted and did you have them balanced?
