I got an OMP strut brace and and I cant figure out how to fit it. Theres no where to bolt it to and Im not enthusiastic about drilling to fit the bolts.
i drilled my holes in my 172 i lined the strut brace up onto where it should go drilled the holes took the wheels off and used ny-lock nuts and bolts to hold it proper on
certainly requires drilling - we used masking tape on the turrets and a pencil to get everything lined up properly.
scary stuff (having never done one before). 2 people doing the job really helps.
if you do go for it then spend loads of time checking and double-checking everything before you drill. Things always move slightly and need to be allowed for.
is the brace you've bought adjustable ? If it is then you also need to consider how it lines up in it's "central" adjustment position. Be very careful to check all of this before you go ahead.
