strut top nuts/disc
  Titanium 182
right as i need new ones i rang renault
the fella on the phone didnt have a clue, he thinks its only a bolt that goes on to the shcoker piston top
but there one that was removed from my 16v was a disc/cup thing with a bit of rubber wraped around It and a bolt that was part of the disc cup bit
does any one have the part number, or know what i need to ask for, hes now asked me to go and see him, trouble is its 2towns away so il need the afternoon of work! :(
and i want them soon!
any one else know where i could buy them from?
  Corsa 1.3 CDTI
OK the rubber it part of a mounting cup. It is indeed a metal nut with a rubber bit round it. According to the Haynes manual it is called an UPPER MOUNTING NUT and requires a 21mm swan neck spanner and 6mm allen key to remove it. It is safe just to remove it in situ as long as you dont move the car as it stops the top of the shock pulling through the chassis.
If you have a look on my lowering guide you can see it there and it is the same for the old and new clios.
http://www.cliosport.net/articles/loweringfaq/index.asphttp://www.cliosport.net/articles/loweringfaq/index.asp
http://www.cliosport.net/articles/loweringfaq/diagram1.jpg
If you become a member you can also get 10% off from GSF (German, Sweedish & French).
Their website is http://www.gsfcarparts.comwww.gsfcarparts.com
  Titanium 182
they seem to have the part i need
but it has no pic and they dont do they bolt
think i best see the dealers
i have asked paul at infinicar, as he has plent of clios and 19s and is sure to have these
  Clio Mk1 Hybrid
Dont re-use the top nut, as they have a nyloc sleeve.
Safer to get a new one.
Renault would do the bolt, the bolt that I think you are referring to is the top of the suspension strut.
New top nuts cost about £30 for both sides from Renault.
James
  Titanium 182
james i need a new nut and a new cup
as mine had to be ground off! odd i know but they were well f**ked about with it!
  Clio Mk1 Hybrid
Dean,
Mine came with the nut welded to the cup, I tried looking for my receipt last night for you for the part numbers, but I cant find it.
I will post the part numbers up if I can find it.
James
