Nope![]()
Pretty straight forward. I have some 3 mm thick washers but decided to do the Renault fix when I fiited my new Koni suspension, as struts were out. I ovalised the top hole in the turret as it stops the knocking. I didn't like the idea of having play in the top mount after fitting washer as some have failed mot's for this.
^impact gun or air gun, is the car still on its wheels? much easier to get them off with the car on the ground
Excellent idea....i had to do that^impact gun or air gun, is the car still on its wheels? much easier to get them off with the car on the ground
I tried with the car jacked up and then on its wheels. I also tried swearing at it but that didnt work either.
I'll nip round to a garage and see if they can crack the nuts for me.
where you get washers from
I'm very suprised you cant turn them when the wheel is on the floor. I couldnt do it when the wheels were in the air but once I had it on the floor it came off no problem. Maybe your not swearing loud enough!
Thats right, the knocking is usally the top part hitting the turret and you can see by the metal worn away on the opposite side, the washer is just to raise the top part so it clears the turret.
If this knocking isn't your issue....you may have engine mounts gone.
When you take to top mounts off you should be able to clearly see if thats whats knocking. The turret should be burred and rusty where its been knocking. o/s will be around 1-2 o'clock and n/s around 10-11 o'clock. The Renault fix is to remove some metal with a dremmel or die grinder of sorts...round file if needs be....around 5mm in the area. This allows to top mount to be re-fitted in its original postion as Renault intended.
The washer fix does work, by raising the top mount away from the turret, by the thickness off the washer used....3mm being chosen by Yozzasport. As i'm not a Renault design expert, I cannot comment on the effect of raising the mount 3mm. But when I test fitted some, I noticed the top mount did not fasten down to the turret as it originally did. This lead me to believe there could be play when the strut becomes unloaded. Others have also failed mot's with these fitted.
