Stud Troque Figures
  ph2 172
Does anyone know the torque figures for the following studs in the F4R cylinder head :
Exhaust manifold studs
Timing belt pulley studs
Should I torque them up to slightly more than the nuts going onto them or the same?
Matt e
Exhaust manifold mounting nuts 18nm
  182/RS2/ Turbo/Mk1
You dont need to torque the stud, only the nut, the stud just needs to be wound in until it runs out of travel.
Matt e
ive had a look and i cant find anything about the studs for the side cam cover.
i would have thought they would be more than that because it acts as part of the engine mount as well
Mr R.
  A special one.
I used to fit 2 M8 nuts onto a stud, lock them together.
Fit the stud and wind it in using the back nut, once tight the back nut will un lock its self from the front nut.
Stud tight. :)
  182/RS2/ Turbo/Mk1
The reason the nut torque is important is that is stretching the stud the correct amount. That will not happen with torquing the stud in though.
