Ok, this may sound like a stupid question, but.....
...each car has a certain bite point on the clutch. Now in terms of changing gear most cars you can change gear by only depressing the clutch pedal a small distance (say 1/8th to 1/4 of the total pedal movement), which is advantageous for a quick gear change. Question is, is there a mechanical disadvantage to doing this? ie, will it damage the car / clutch in any way? Should you depress the clutch further for any reason?
