sub enclosure wadding ?
Car  E87 118i
should I stuff my box with some wadding ?
I've read that it helps stop vibrating etc and that it also helps to make the enclosure appear bigger than it is ?
if my fiberglass encloure is big enough should I still put it it ?
should I use that white quilter's stuff or this other thicker stuff (simlilar to the stuff under your spare wheel) that I have seen used?
thanks
I believe that one of the best things you can do is get carpet underlay (the green stuff) and staple it to the internal surfaces.
This is on the recommendation of Erskine Fenty/Fenti/Fentie, Sub Box Builder extraordinaire!
