I dont know why, but on a junction this morning on the M1 the amp stopped working, I have checked all the connections and there all fine. But there is no power to the amp...any idears?
first of all bridge the remote with the power if it comes on you know its the remote connection causing the problem it still no power it will 100% be a blown fuse or bad earth perhaps the retaining bolt or nut you may be using has come loose if still no joy then your looking at amp failure
yes the earth being wet is bad i would locate the source of the leak and resolve it immediately and perhaps reposition the earth being a mk1 if you have an external leak it will most probably be coming from the rear window seal try lifting up the inner edge and spraying some wd-40 to stop the water coming through also if you have a leak there the chances are your have rust under the seal aswell so the wd will pro long it, is the lower inner boot rusted at all?
an excess of current could be to do with how loud you have it playing and what your amp settings are and if at any point the earth has been broke of weak or maybe your just not using the correct value fuse are they agu fuses then?
