SUB WIRE INTO STERIO
Car  Clio mk2
so i fitted all the other wires to fit my sub but cant find a hole through the back of the stereo to connect my sub wires, is there one or should i make one or what??...i got a clio mk2.
Total lack of information on this fella you need to say what wires. Are you talking RCA's or remote wire? assuming you've already connected the sub to the amp and run the power and earth to the amp from the car? Also are you trying to wire it to an aftermarket or factory head unit?
Yeah, need more info.
If you have an aftermarket headunit, that's a start. You should have a set of RCA's (red and white) and a remote lead going into the rear of the headunit to the amp. Power lead going from the amp to the battery, earth lead from the amp to the car chassis, and some speaker wire from the amp to the sub.
If you have a factory headunit, you may be stuck I think.
i have an aftermarket cd player and im trying to wire the remote and RCA wires into the back of my head unit, i just ned to know if there is some way i can get to the back of the headunit through some sort of hole?
You need to pull the head unit out of the dashboard, then connect the wires.
see thats easy done but its actually putting the wires away ie, having the wires behind the head unit itself but u cant find a hole to thread them through.
there is one there, I slways start from the frontwhen doing installs. Take the head unit out and run my RCAS and my remote cable from the head unit hole and work my way back.
However, my new unit has a processor box in the boot, so easy to wire :D
lol well thing is i looked down the head unit and can find a hole that comes out the back near the glove box, is there even one in a clio mk2??
ive put stereo systems into literally a hundred cars, And I Can confirm that a clio mk 2 is one of the easiest.
Have you got your power wire through the bulkhead yet?
The hole i used when i did my mk 2 phase 1 was down by the glovebox, Cable tied it under teh glove box and came up the passenger side of the car.
yea i have the whole were ill put the power cable, not wired it yet but im going through where the bonnet release cable is. when i put my hand under the glove box around the back of the stereo i cant seem to find a hole at all is it kind of on the side of the back of the stereo or directly behind it?
Try and divert the wire towards the drivers footwell as i assume thats where your puttin the wires?? Watch they're not in the way of the pedals though
well i want to wire it down the passenger side but if i have to then yeah the drivers side will do thanks for the info m8. :cool:
I assume the power cable is down the passenger side??
yea it all goes down the passanger side, i got the grommit out just need to feed it through 2mora its not good workin in the dark! i know if i can get the cables through the back into the head unit then ill get the power cable fitted up and ill be boomin, lets hope anyway.
