Subframe question
I'm ready to drop the subframe to remove the gearbox do i need to unbolt the steering rack as well? if so is it just the 2 16mm nuts holding it on?
  BG 182
Theres 2 16mm bolts per mounting bracket, remove all 4 and iirc you can leave the column bolt and the two captive M8's alone, make sure the rack is adequately supported :)
