Sump gasket leak
Car  Inferno 182 & Saxo
Got a bit of a leak on the sump gasket ( ive been putting up with it for years but its got a little bit worse recently) so I intend to change it.
Whats the easiest way to get the sump removed? Ive read its recommended to remove the sub frame but I dont really fancy doing that if possible. I dont mind remove the bumper and what not though.
Engine up as high as possible on drivers side and you can get it off, bit of a fiddle but can be done.
Replaced mine & used Renault Gearbox Sealant on the new sump gasket & don't get a single drop from it now!
