Gavin.
Thats what i'll be doing temporarily until i get chance to sort it properly. it wont look that neat mind
how long is the piece of Mastic? Will one be enough or should i order two??
Thank you for your reply.
I would like to ask you one more question.
Is the sunroof more than 2 pieces? The metal frame under the roof and the plastic frame which goes over the roof.
What i have sone so far, is add some mastic near the drain plugs as i believe there is a gap on the plastic there as well.
Yes it does make sense.
I will get a pic tomorrow to show what i have done so far.
It's the Renault way - tried and tested about 50 times so far!!
If it's the 'renault' way how come renualts leak. Obviously not that tried and tested seeing as theres a major issue with there roofs.
