Sunvisor Lights
richard691
Car  Twingo RS133 & 172
Is it the 182 which has the lights in the sunvisors which turn on when you open them, if so is there any way you could install them into a dynamique and still have them turn on when opened?
Why you'd want them i'd never know.....i could see why a lass might want em but by your forum name i'm thinkin your a guy......maybe try some breaks matey?
Its cool though, esp if the interior lighting is a certain shade/colour
have you ever tried switching all the lights on inside the car at night? its cool, very bright. or maybe i'm just daft.lol
16vClio said:
Why you'd want them i'd never know.....i could see why a lass might want em but by your forum name i'm thinkin your a guy......maybe try some breakers matey?
That was meant to read.
Al
they just look good mate, like my gadgets. So are they from a 182 and how would you go about powering them?
So how would you get to the back of the interior light, does it pop out or is there a way og taking the head liner down?
your daft, lol ;)
only joshing! would quite like this idea for myself once i've done the leds in the dials etc
yeah screwdriver would work. It'll probably say in the manual how to take it out to change the bulb, will take about 2 seconds to take it off!
Solder or bullet connectors or heatshrinks. Soldering would be quite awkward cos of where it is. Any sort of connector would do the job though.
I've got some bullet connectors, how would I split the wires because I couldnt jst connect them as there wouldnt be a feed from the powe supply then?
You can probably tell I dont do these sort of jobs.
Looks like that. Get them in maplins, halfords etc
So would you just use the 1 connector and crimp the 3 wires together, 1 from each of the sunvisers and the other 1 from the interior light?
Sorry hadnt noticed a reply.
Personally I would connect both sunvisors lights together and then that wire into the pernament feed. So 2 into 1 and then into the single live.
Get 1 wire from 1 sunvisor and out it into the scotchlock and then put a longer one from the other visor all the way through the scotchlock. Then put that into the 2nd scotchlock and connect that to the interior light wire. Kinda hard to explain without pics. If you are still unsure take it to a ics install place and get them to do it.
So i need 2 scotchlocks or could i just put the interior light wire through the scotchlock and then put one wire from each of the the sunvisers and put them either side of the other terminial in the scotchlock?
Another thing, when i phoned a breakers yard up today they said that you just pop the interior light out and there should be a block connector there for the sunviser lights, even in a dynamique and you just connect them up to the connector on the sunvisers. Is this true?
Thats a good diagram mate, cheers I fully understad that. So what do think about what the breakers yard said about there already being block connectors there for sunvisor lights, is this true or rubbish?
