Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
I Bought an ECU for my 1.8 16v ph2 like an idiot without checking the chips inside were the same as mine. Does anyone have a table showing which superchips chips replace which ecus chips? If its the same replacement part then ill just swap them over
They both came off a 1.8 16v ph2 they look exactly the same with a few minor differences they have the same part number but the chips inside have different numbers on them. When i put the new one in the temp shows 16c in the dash and the immobiliser wont turn off.
it will if u do it right! r they both soldered directly 2 the board? (i.e. no carrier). if so, like u say de-solder both, swap them round makin sure chip is in right way round, re-solder (makin sure not to put a big blob between 2 circuits!!)
