suspension - HELP!
Car  Clio 197
My rear shock got a leak:(.........my poor car:cry: lol
Which is better to replace??
1. Same Renault standard shock??
2. New suspension kits??
3. Will mk2 ph1 172 kits fit on my car???
Many thanks
Giles:)
172 kit won't fit even if it did it wouldbe be the best.
Stock shocks won't be to expensive.
I'd go for Fk's I'm in the same situation at the moent as all my shocks are going not sure what to go for as I need to save money and stock setups not bad.
^^I don't understand why 172 kits won't fit??
If I put a 172 engine in it and will the kits still fit??
The hubs are the wrong size.
If you put a 172 engine in you'l also need the 172 hubs shafts brakes etc (for simplicatity) so then you'll have the right hubs.
