suspension noise
  Trophy #473
hi all
when i pull off from a stand still, just normal driving, i get this faint clunking sound from my drivers side, when i also lift off it clunks sometimes, i have had a leaking CV joint gaiter which i then tightened up, and do wonder if its a mullered CV joint. but when i do over bumpy ground fairly slow there is a really loud knocking noice from the front end and you can feel it through the wheel. I thought i had a worn n/s damper but that wasnt the case. Im thinking top mounts but havnt a clue what worn ones would sound like or the symptoms:
on a lighter note i have fitted a GDI ;) fast road brake kit and its fantastic! thanks again andy for quickly processing my order.
nathan
im thinking i have just answered the questions myself but just want to be sure before i spend ANOTHER FORTUNE FIXING MY RENAULT
  GDI Demo 182, Rsi Spider
you must get it on a ramp and get it checked, just in case....
could be all sorts.
bottom ball joint
top mount
anti roll bar mount
cv (as you say)
Andy
