Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
depends on the size of the hubs.. if your hubs have 54mm distance between the bolt holes then the valver suspension will fit. if it is 52mm get yourself some valver hubs for about 30notes
thats why you swap the springs over using 1.2 ones as the valver ones are alot stiffer due to a heavier engine
You dont have to swap the hubs if they are already 54mm
as said above the valver suspension will be a straight fit as long as you have 54mm hubs - and there is no need to get valver hubs as long as yours are 54mm. However it won't lower your 1.2 60mm - will probably be more that that as valvers are about 35mm lower as standard anyway, however on the other hand the 1.2 isn't as heavy so it won't go 95mm down or anything either.
