t-cut?
  Mk2 Clio 1.6
i have been using t-cut on my OZ's to get the yellow from the brake dust and salt off of them.
is there anything safer but just as good?
  Megane R26
I would try a Tar Remover of some kind, or if not, use a clay kit - should be a bit safer.
Alastair.
  986'S 172ph1+182FF
i used brick acid from b and q on a set of fuked clio wheels, came up like new after a good polish.
wonder wheels is v good mind
Bilberry neat to clean the wheels up, Tar remover to get rid of the tar etc, Clay if any still left then seal with SRP > EGP. Or Poorboys wheel sealant.
MRBILLYUK
  FF Jeden Osiem Dwa
Wonder wheels should shift it , it's basically a more dilute version of Brick acid , both being hydrochloric acid :eek:
