clio 172 2004
ok so i installed my autometer tacho a few months ago and all readings were at around 40 percent of the actual rpm.
the above was connected via pin one orange cable on the coil pack to the green cable from the taho
what i did today was connect the green cable from the tacho to the orange cable and also to the cream pin two cable on the coil pack it felt like it was losing power. but this was done in a very temp' manner to see if it would work. what i was thinking is if connect the orange and cream (pin and 2) would cause problems could i connect my green cable from the tacho with a one way current flower and than connect it to both cables.
the reading was correct from the last test
cheers all
cheers all
