Tcp / Udp.... Help!
  Clio 197
What on earth is all this?
Basically, I can't get connected to the Nintendo server with my nintendo DS.
This is what I've read:
Sounds like you have a firewall blocking UDP ports. Nintendo say in order to use Nintendo wifi you need to allow all UDP traffic and TCP ports 28910, 29900, 29901 and 29920.
So, on my application gateway list, what on earth do I put?
Trigger Port / Trigger Type / Public Port / Pulic Type.
Ta,
Oms. :D
  SLK 350
Trigger port - ignore.
Trigger type - ignore.
Public port- enter the numbers it states.
Public type - set to ANY or make one for UDP and one for TCP.
  Clio 197
Cheers!
The router's accepted them... only my DS still won't connect.
I suspect there's a compatibility issue between the router and my DS.
I'll drive up the road, and test it with someone elses wifi router. ;)
