technical
when u go and get work done to your car, how do they know how it should be? i.e. if ya getting ya tracking/geometry done.. how do they know what it should be for your car?? and is this info on the net anywhere for all to see?
had my tracking done by ripspeed once and I recon they were just guessin
my mate did it again 2 weeks later and said it was way out
if its lowered it not the basic toe settings that are effected, but your static settings for camber/castor and further affects on bumpsteer will be afected, but since we cant change it.....dun worry...
can u find out the info like this that garages use on the net though? not just tracking either.. i want the FULL spec! for me 16v really.. but others would be interesting too
Handling is a personal preference. Some people like going sideways and others dont. Play with the toe settings but dont toe your wheels out (its well dodgy..). If youve got a powerful FWD and drive it hard, then as little toe in as possible is a good start, or dial out some toe changes under acceleration/torque steer by fitting stiffer wishbone bushes. This helps the castor and camber control aswell.
As Ben R sez, bumpsteer is the usual cause of bad handling on mass-produced road cars, and if your car is lowered it will be very sensitive to toeing out under load (i.e. bad understeer). You can reduce this by removing the tie-rod ball joint (the bit on the end of the steering arm) and replacing it with a female rose-joint and an steel insert through the hole in the hub. By changing the length of the steel bit, you can change the angle through which the steering arm moves with suspension compression - which leads to toe changes (i.e. bumpsteer). Ive done it on my kit car by changing the rack height, and its pretty effective.
Have fun :)
Im having major problems sorting my MK1 XR2.
the chassis doesnt like being too low, but it doesnt like the high CoG either!
so, its low as neccesary, but now the roll centre is too high!
Have to buld adj TCAs, sort the bump steer, which isnt too bad, build some adj top mounts as castor isnt adj....pah, so much to do.
Anyway, you cant play too much on rd cars, and the results that that get back will be minimal, i dont think many will even try sorting any form of geometry apart from toe. Of which on a rd car you just want a teeny bit. try 30 mins to 1 deg.
Whats your kits car?
Its a Robin Hood 2B...silence....yeap, theyre a pile of crap and Ive spent three years trying to build the thing from my 2K worth of scrap metal they sent me. It has awful sliding pillar suspension which Ive fitted to get through the SVA, but Im now in the process of making a double wishbone setup with rose joints and tasty bits.
XR2s are cool fun. Incidently, if youre a bit of a hands-on person, try making a long toe link from the TCA to the chassis behind. Its quite effective. The changes in castor are outweighed by the crapness of using the roll-bar to locate the TCA - esp when its on flexible bushes. You could replace the roll bar with a bit of tube and some drop links stuck on the end with holes in them for different lever ratios. That supercharged-turbo-nitrous jobbie in CCC this month was quite funny - seriously fast!
Steve
Oh yeah, I forgot. Ive seen on the Triple Eight Astra touring cars that theyve got a spacer block under the hub where the wishbones join it. This could raise your roll centre without raising your C of G. Means you dont have to modify pick up points. Well worth it if youve got clearance between your wheel and hub.
Steve
yup! lol
Its got no fron ARB, only a rear.
The toe link, youll have to expends, got the gist, but not the positioning.
Need to sort the rear panhard first, on the track the rear axle can sway about 1.5" either way.........need some dead beefy items.
Steve
BLOODY GOOD IDEA!
would reduce camber too at the same time whilst im building the adj items.
top suggestion!
Toe link is the bit that acts as a prop for the TCA - bit like converting it into a wishbone.
Panhard rod?! Brings back days of the Escort Mk1/2. Suppose they didnt make any forest spec XR2s. lol
infact, they DID!!!
but it was the supersport for some woman rally driver, forgot her name.
to bad its not RWD or a watts linkage would solve that prob, bit i need to make some beefy beefy items now......lol, the things we do.
Withthe toe link, if its not parallel, or mirror image of the TCA, how will the arc follow wihtout creating changes.
Some good ideas here mate, Ta!
Ah, thats the compromise bit. No suspension travel = no problem! lol
Looks like youve got your work cut out. Sounds like youve got a good excuse to make it RWD :)
