Temp gauge problem.
Car  Clio 200
Please could someone point me in the right direction.....
I fitted a chipped ECU last night and now my Temp gauge is always at the bottom of the gauge. could it be a sensor or maybe the new ECU..???
thanks
what car is it, ensure the connector for the ecu is connected properly, check the wiring to the temp sensor , the accual sensors are pretty rugged its the wiring that can become snaged or frayed
if you replaced the ecu you may have knocked the wire as they are near each other, check all plugs etc........
