Thats me on the turini bangwagon...
cristophe you can buy them from k-tec, think they are a grand ish.:dapprove:
if you do find some second hand ones be careful of the offset, you really need them at ET42, if you go any lower than that, you could risk them catching/rubbing etc because a lower offset will stick out more.
If you phone k-tec they will tell you the same.
just a bit of advice tho.
iirc a set of 4 turinis from ktec is around the £750 mark.
not to bad. I have 17" wheels now so think i could get 300 quid for them which means i only need to spend 450
Unfortunately mine are 172 offset, there looks to be plenty of room under the arches, will the 25/30mm ish drop from prolines cause me any grief?
look good!! glad u recieved them fine :)
they will defo look good with a little drop!! i had them on the cup when it was lowered 30mm front and 50mm rear on the H&R's!! slight scrubbage till i got the car setup by Mark Fish!!
the 172's wheels have different offsets,
The cup is lower offset than the full fat. so if anyone wants to correct me if i am wrong but i think a cup will be fine with a lower offset wheel fitted to it
im sure i did read that the suspension set-up is slightly different on the cup
