'03 MCS, MKV Ed30
Some great shots uploaded since my last visit.
Scott - Regarding the whole aperture thing, landscapes I never drop to f/5, ever. My landscapes, and more so sunsets and rises, are almost always shot f/16-f/20, or if I have some prominent foreground, i'll shoot f/9-f/11....i'm not saying this is right nor wrong, but it never fails me (this is shooting UWA Sigma 10-20).
The first one here for example, f/18 and tack sharp front to back.....
Here's a couple more from me...
Loch Lomond sunrise by Martin Steele., on Flickr
Eilean Donan Castle by Martin Steele., on Flickr
The boathouse by Martin Steele., on Flickr
Martin I think you may be confusing sharpness with depth of field.
Some notes on sharpness below that can be found on google. Note how the below notes correspond directly to the canon/sigma 10-20 MTF chart (attached) unfortunately the chart only goes to F11 but you can see the sharpness drop off already by F11 over F8. By f16-f22 its significantly lower again.
As a rough rule of thumb F5.6 -F8 should get everything in focus and will generally be the sharpest apertures to use for across frame sharpness landscapes. I might drop to F11 if I have foreground interest for increased depth of field.
“Sweet Spot” / Optimal f-number:
All lenses have an aperture setting, or range, that is called a "sweet spot" for sharpness. Each lens is different, but as a general rule of thumb, the sharpest images are taken with the aperture 2 f/stops down from the widest opening. So if your camera has a lens which is wide open at f/2.8, then the "sweet spot" will be two stops down to f/5.6.
But what many photographers don't realize is that you will also get "softer" images with the aperture at its smallest opening, due to diffraction (light rays get slightly "bent' as they squeeze through very small apertures, resulting in you getting progressively less sharp images beyond a certain aperture). When you use smaller apertures (larger f-numbers) to achieve a greater depth of field, at some point the aperture size will cause some softening due to the effects of diffraction.
For landscape shots, unless I'm trying to get the longest shutter speed possible, then I'll be anywhere between f8-f11. That's the general 'sweet spot' for most lenses.
You shouldn't really be using really large or small apertures for landscape shots.
