Thick ice inside windscreen grr
Seeing as its been super cold and snowing laterly my windscreen has been just as frosty on the inside as the out.
Whats causing this and is there a cure for it.
All my friends don't have this problem or if they do only normally mist.
Cheers elliott.
there is a solution but its at your own risk..
Boil the kettle so that its warm, then slowely pour it over the windscreen with the wipers on(spread the warm water along the windscreen better) it should be just warm enough to help clear the windscreen
Iv been doing it for over 3 years and it hasnt resulted in a crack windscreen or nothing,
Boil the kettle so that its warm, then slowely pour it over the windscreen, it should be just warm enough to help clear the windscreen
I just use hot water out of the tap tbh!
I had the heaters on full with the doors closed and it took over 10mins just to clear a small patch.
I had to use the scrapper on it today.
Use the airco to 'dry freeze' the inside!
Guessing it is too moist inside, so freezing up.
Or do you turn the heat up to max. on the blower that much?
Warm air inside condensating when parking overnight after driving around?
ahh, but we live in the countryside and the water take a few min to warm up, but sometimes the pipes freeze :dapprove:, so that why i use a kettle quicker, and i can just pour it on and go
So do I mate! First thing I do when I wake up is light the fire! lol :)
Did this last night at 2am! Outside defrosted and the inside didn't lol. I just rev it at 1500rpm to warm the engine up more, the blowers give more power when having it off the normal idle anyways.
Bet your neighbours love you ;)
Buy yourself a big bag of cat litter. (The sort that is like white crystals not the grey powder stuff) Pour it all over the carpets in your car and leave for a few days. It will absorb all of the moisture inside the car and stop the interior ice problem. You can then just vac it out. Worked on my old Megane.
lol sounds like a good idea, but you'll have loads of cats sh1tting on it ;)
i just use the liquid de-icer stuff from tesco
That is the worst stuff you can use.
Mine takes 4-5 minutes to completely defrost just sat on idle with the heater on max and the rear de-mister on.
Maybe theres a problem with your heater if it's taking 10 minutes to defrost the car?
Or get silica gel sachets and put in the car, that'll absorb the moisture without the mess of the cat litter!
excessive moisture is obviously getting inside the car for you to get ice on the inside of the windscreen. I would put my money on the windscreen seal has gone. Get someone to refit the screen or if you feel flash buy a new one
Id buy a couple of the big ones that are on the Bay. 600g I think. put them on the dash when you leave the car at night, or put them on the floor or wherever.
Make sure the pollen filter isnt fekked, if its not changed regulary it can cause said symptoms
Also lol at the reading fail in here, pouring water on the windscreen, the op's problem is INSIDE ;)
Thats for all the suggestions. I think i'll try and get hold of some silica stuff. Its only the windscreen thats has ice on the inside in the mornings or in the evenings when leaving work.
My 1.4 S has this problem aswell! Its so annoying after a late shift when I just wanna get home but the screen is iced up on the outside and the inside!!
i'm only just getting it now after 2years of ownership. my sunroof seals are fucked so maybe that could be a thing to look at ?
