things that go bump....
Gaz_
  Extreme mode
got a bit of a funny noise (whats new) happening on me 172 cup...
driving normally or giving it a caining, its fine through all speeds, but when locking round a tight right hand bend at low speed (u-turn) type move, i get a funny noise that deffo comes from the rear, its not a clunk, sounds more like a suspesion problem, like a spring rubbing/fowling something!....?!
ive had some ebachs springs fitted since xmas, but this has only happened recently...
any thoughts?
cheers
[Edited by gt_gaz on 06 February 2005 at 6:44pm]
[Edited by gt_gaz on 06 February 2005 at 6:45pm]
maybe your exhaust rubbing on the rear sub frame, I had that problem after fitting eibachs then a ktec stealth zaust. Found that the muppets for fitted the exhuast used the old rubber mounts which were shot, so i bought a new set fitted them and happily nothing rubs now
Gaz_
  Extreme mode
could be........ ill check that cos its had a rear silencer under warranty by the previous owner, which has been fitted by reno, and surprise surprise, blows on the joint.... could be that the box is not sittig right, ill have alook! its bloody embarrasing when it happens though :(
Gaz_
  Extreme mode
found out its the drivers side rear shock, it absolutly f**ked, pissed out all its fluid, on a two year old car!! anyone else heard of this!!?
