Thinking of buying a DCI 80, anything to look out for ?
J
JEFF4507
Hey guys,
I am looking at various Clio dCIs, but the 80 seems the best choice mainly for insurance purposes. Although to my knowledge the 100 seems to have a much larger power band.
I will be modifying whatever I end up with but all of the different models are getting on my nerves, have seen an Expression with air con (no alarm or fogs though) with 17000 miles priced at £6k, will haggle him down a bit is this a fair enough range? Alloys aren't a biggy as I would get my own anyway.
For internals, I was looking at the K&N 57i, a Cat bypass of some sort (perhaps Magnex) and finally with a superchips remap.
Any comments would be appreciated.
  Audi TT 3.2 V6
what year is the expression mate? my 1.2 16v petrol (expression + with aircon) on a 51plate with 35k on the clock was £4k (6months ago), if the dci your looking at was also a 51plate i would perhaps be looking at paying 4.5k as it is low millage, not sure i would be able to justify 5.5-6k for it though.
J
JEFF4507
Sorry forgot that bit :eek:
It's a 53 plate registered september (so this is the last year of servicing). Have looked at others, seen a Dynamique for same price same milage but no air con.
Read that the Dynamique has sport suspension, would this be expensive to put on the Expression ??
  Audi TT 3.2 V6
you could prob get a better suspension than whats on the dynamique by buying uprated shocks and lowering springs so i wouldnt worry too much about that.
id go for the aircon if possible, clios with aircon are quite rare and because of this hold their value a little better. is say 5-5.5k is a fair price for the expression u mentioned with it being 53 plate :)
J
JEFF4507
Yes that sounds alright, thanks for the reply.
Have been driving a 1.25 zetec fiesta for the past year, and after crashing that, I'm onto a Metro as a "between cars" option (yes I know... ouch!).
Quite looking forward to my first turbo diesel, some actual overtaking power.
There not a huge amount in 65 to 80 difference wise the 80 suffer heat lag (its not that bad though on the 65).
The 100 is good shame the engine derated for the grearbox but thats life.
Personally if your going to modify depending on insurer I'd get the 65 the gearbox isn't the limiting factor but the 80 and 100 have stronger boxes so its a game of give and take..
£6k seems a bit high I'd sell you my 65 for £4.5 have a shop round you should be able to pick up one cheaper I'd make sure you get one with warently and get an extended warently as the engien if it brakes can be massivly expensive (injectors are £250 a time).
No need for a indction kit if you get an 80 just get a custom remap not a superchiop but a custom remap will be difficult as there only 2 companies who i know can do them and there both abroad but I think one has dealers in the UK.
The car doen't have a cat as such there a particle filter and you can take the inters out but unless your maxing out other bits its not worth it.
Aftermarket suspension is better than any stock Renault stuff even 172 stuff isn't as good as the aftermarket none RS stuff.
I wouldn't get air con though it make the front end a bit heavier its more to go wrong and if your like me keep getting stonge in the front of the car then replacing the conderson bit will be very expensive plus ones with A/C are slower (slightly)
J
JEFF4507
@Edde.
After checking, the difference in insurance premiums for me, is nothing between the 65 and the 80, and £100 more for the 100.
Would you recommend waiting for a decent 100 to become available ?
I think I would get bored with the 65 and would have to do those modifications just to bring it up to the performance of the other 2 models.
You mention a remap, this is essentially what superchips do, however they tailor it to suit the car whilst on the rolling road(ideally after you've finished with everything else, intakes and exhausts namely). The power increase on their website states roughly 20 brake for each of the dci models, however I know they can produce more power, at the expense of black smoke. My cousin had his 330d at 320hp and 730nm !! Chugged a bit of smoke at the end of the gears though.
I want something with some poke really, I will be traveling daily on carriageways and motorways soon enough and would like to do it comfortably.
AC can affect performance minimally, and in the event you want to use all available power (not on public roads of course:sleepy: ) you switch it off. Or are you suggesting there is a general problem with Clio AC units ??
I read your post getting hints that you're not a great fan of the dCI Clios, not knowing much about them myself, would you say they're a good buy, or to perhaps look at competitors ?
You also mention an issue with heat lag in the 80. Surely a bit of heat shield would sort this out.
Thankyou for the reply.
J
JEFF4507
Hey, me again :dead:
I have just been offered a 2004 Clio DCI 80 Dynamique [AC] for £6k. Seems like a better deal than the Expression, this has done 13k miles, is metallic (the expression wasn't) and has a year of warranty and the first MOT is covered also.
Haggle him down a bit ?
  Audi TT 3.2 V6
sounds good mate, dynamique will have alot more than the expression....sports seats, sports suspension, cd player as standard, sounds more of a deal 2 me :)
J
JEFF4507
Yes I think I'll go for it. Still will try to get a couple of hundred off, looks like a nice little car.
Depedns try them all the 65 and 80 have nicer gearboxes against the 100 which uses a Megan derivative gearbos. If your intending to modify then you have to remember that the 80 and 100 is already at the limit Renault specify for the maximum allowed torque. There no spare capacity if you push it from now on you have to remember Renault could have given it this much extra but the gearbox reliablity wouldn't.
The 100 will give a fari increase in torque as its capped but as i said the engine was capped to protect the box long term.
I'd say try the 80 and 100 the 100 is nice and a bit quicker but then there the poor box to deal with. The 80 is a good balence the saved insurance stick towards a ttunning box and you'll have more power.
The 65's not bad at all its quick enough. More important than the hp is the braking and handling coilovers will make more of a difference than twice the amount spent tunning the engine plus it arguably looks better and doesn't impack the warently as suspension bits are cheaper and less likly to be refused warently work.
Smoke from a turbo diesel means wasted fuel it means the mappers have gone to far in the extend of all out power it damages the turbo etc. However many people thing it makes a car better. it does give some extra Hp though just at the cost of engine life.
Superchip as far as I know don't do proper custom remaps they may fiddle the fueling a bit more but a proper custom remap involves ages of work.
you cna get about 85hp froma 65 , 105 from a 80 and about 125 from a 100 before you start needing other bits chnaging.
A proper remap along with an intercooler on a 65 will see 100hp though.
I use my car on the motorway a fair bit its no trouble the higher hp versions have lower gearing but there not that much lower. There not quick by any means any of the serioes get a VW130PD engiend car if you want to go quick.
There no problem its just the loads is still on the engine even if its only slightly there even 1hp is a 1% of power on the 100. The problem is (although noone else seems to suffer this but me then again myabe the ay I drive/whee I live) thats the stone chips damage the radiator. I'm on my 3rd in just over 3 years. the A/C would normally be in the way so this would be damaged instead and a A/C radiator is even more expensive.
I love the dci there superb cars I've done 59k in mine without any trouble any 1.2 would have had more problems than I've had I get 29.8mpg on hard track use 37mpg on absolutly made hard road useand 55mpg hard driving to and from work . You can easily get 80mpg road funds £85. More importantly the torque low down is great its one of the things I don't like about the 172/182's that if you pull out of a bend you'll be ding about 3.5k in the 172 and 2k in the diesel the diesel will pull harder than a 2.0 until the 2.0 can get its revs up. Have a look at competitiors though the Clios great fun though I looked at the Ibiza and I was very unimpressed the Skoda I'm guessing is the same (they havn't phoned me back yet for a test drive).
It depends what you want for a car reliablilty, warently, running costs, track day use, fun driving, and the amount fo cash you have to spend as to whats best. I don't have anything against them I just like people to know to have an open mind about things so they don't think the Clios the only oen the only reason I'm going to get rid of mine is the next service is 72k and costs about £500 which is a fair % of the value of the car and that I want something quicker.
Its the 65hpwhich suffers heat lag as there no intercooler best way to decribe it is when ou book it from standstill by the time your at 60mph you can tell (I'e owned the car a while so I can tell) the engine pulls back power slightly as the intakes temps have got to high its not a huge loss though of power just annoying.
Soudns like a good buy.
Always try get a few hundred off though.
Ring Renault dealerships and see if they will sell you a extended warently (you don't have to buy till just before its 3yrs birthday but make sure they will sell you one).
J
JEFF4507
Thankyou for your time.
I just need a car that's reliable, comfortable, cheap to run as realistic, that will cruise comfortably between 80 and 90 on motorways and that is a bit of fun to drive on tracks and B roads.
I always said to myself my first car I buy will be a diesel, have looked around and from statistics, the Clio suits me best. Insurance isn't a nightmare as it's a 1.5. I have looked at VW and Seat but the insurance on the 1.9TD is silly for me.
I will most likely leave the car stock for a while to get used to it, perhaps throw some 16" alloys on it (do these fit btw, I don't plan on dropping the car to the ground), then eventually may divulge into an exhaust, filter/induction and finally a remap.
The 80 seems the better choice as I wouldn't have to find an intercooler as you mention. The 100s are a lot harder to find, and tbh, it's just for a few more starting horses. And you mention the gearbox aswell, that's something I'd rather not have to replace any time soon aswell.
Do you know how the 1st MOT deal works ? I know the guy I take my cars to, would he be able to fail it, claim a few parts and have Renault pick up the tab or are there limiting T+Cs ?? Such as must be done by a Renault dealer ?
Engine Hp doens't make much impack on fun driving wise infact being as you can drive flat out more smaller engiens can be better.
Mine will do 115mph indicated on the clocks in a strong line (proved in Germany)so its not that slow plus it was loaed with 2 people and a book full of spare parts.
No Mot wise it won't fail there no emmsiosn as such so you cannot realy fail.
As regards waretly nope all warently work has to be doen by Renault delaers who then claim the money back from Renault noone else can claim the money there a stupid long procedure to become a dealer.
16's fit yep no problem I used to run 15's with a 60mm drop (claimed) without any trouble.
The 100 box is a different box than the 80dci and its stonger.
I'd change the oil ever 9k as it makes a difference much better with fresher oil.
J
JEFF4507
Hi,
Yes the smaller petrol engines would be more fun to race in a straight line, but annoying thing with small capacity petrols is there is no torque for corner exit speed, this is where diesel gets the grunty advantage. It's not really that important.
Which box is stronger ? The 80 or the 100 ?
I was more joking about the MOT, I meant could I have my friend fail it (falsly) just to put on the paperwork that it needed new parts, such as clutch and gearbox would both be nice to have new :rasp:
I shall enquire about the extended warranty and shall sort something out today to buy the car, getting very excited.
P.S. You say you saw 115 on the clock, from experience Clio clocks are VERY unreliable at high speed, a friend's 1.2 was showing 120 on a straight piece of road:clown: which I don't really believe.
GPS is the only way to test that though I guess. I'll just be glad to have working electronics in the car. The Metro I have at the moment has a dead 12v socket, no radar detectors or PDAs in that car !!!:dead:
The 100 has the stronger box its a dirivative of one used on the Megan. Bit its not very nice to use box the 80 has a nicer box.
More important than Clutch and box would be the injecotrs and turbo my gearbox has been slight trouble reciently but that maybe just pure chnage its done 58k and been through about 5 sets of front tyres so thats should give you an idea how I drive.
Yep 115 indicated isn't that acurate I've got tom tom now but yet t be back to Germay but about 108 would seem realaistic but I did have my foot to the floor for a few minutes
J
JEFF4507
Haha, how you drive, paint me a picture !
Is germany your code word for the M4 ???:rasp:
J
JEFF4507
Looks like you had fun at Donington !
Seems to grip well on some of those corners, are you happy with the handling ? For what it is of course.
I'm ever happy for what is just a sporty shopping trolley. The suspension could do with being harder but its not desinged for what I do with it as an owner.
Grips superb on the standard compount Continentials it would go even better with coilovers or suspension changes sicne I have to run very high pressures (37psi cold) to stop the tyres wearing heavily on the sidewall so the tyres are basically round with less surface area.
J
JEFF4507
I would never get insured for a 2 litre petrol at the moment, not for anything half reasonable. The other issue would be, what kind of 172 will I get for £6k ??
I doubt it will be in as good nick as a £6k dci.
You should get a decient 172 for that much you can pick up Mk1' 172s for £4k.
However there diffrerent cars I worked out for me it would cost me just in service fuel and insuranced an extra £180 a month thats before tyres etc are added in.
J
JEFF4507
I quickly worked out (after reading those figures) it would cause me great pain !!
