Those of you fellow strippers....
Car  172 5HED
Does your car get f**king roasting??
Since mine has gone totally bare, It gets unbearably hot!!:dapprove::dapprove:
You're not one of those knobbers who drive about with your top off are you ?
:D
Edit.
Oh I see - stripped out car.
Yeah I knew that...
can't say i've noticed any difference tbh, i just open the window a bit!!
Out track car is terribly hot. and you can not open the windows :(:(:(
I look like ive been swimming when i get out some times :(:(:(
Track/race cars are usually very hot, especially in warmer weather. Just have to get used to it - take on enough fluids and you should be ok.
LOL I was like that at FCS before it was stripped!!
Mine is fine but only the rear is fully stripped in mine at present.
Mines all gone mate, just a dash!!
Yup, I guess mate!! Im fending off getting a cup racer roof vent as they look gash....:nono:
i know these problems too, i try to explain one solution :
you can cut a hole (30-40mm diameter) in your mirror holder an the metal of your door behind the mirror, then you remove the cover inside the door.
then you can put a flexible hose in there, when you are on track the wind blows in the car, normaly i wear a helmet so i can put the airstream directly to it or a little below to the suit;)
have to say, i´ve done this to my old opel (vauxhall) vectra, my track b**ch
I drove my car yesterday to pick up a few bits and pieces. It's got no AC panel (I have replaced the heater matrix and dashboard with Mk2 versions so I need to do some wiring before I get the luxury of moving air through the vents again).
It was horrible! (And I don't even have a roof!)
Mine is unbearable sometimes mate! Its either baking hot or has ice on the iside of the screen and icicles on the roof!
I havent noticed in getting too hot. Although I was stuck on the M4 for about an hour the other week, and the area above the exhaust got bloody hot!
Should be good in winter ;)
This is why you need to keep some cooling and heating in the car...and so the vents work; the dashboard as well. Pet hate is people who remove dash boards. Nooo neeeeeed.
Here is the interior of a proper track car. Mmmm nice dashboard, OEM air vents + a tidy looking hose to blow air at the driver (can be seen behind the steering wheel), no doubt connected to an aux. fan with a switch to turn it on/off or a bit of extra cooling.
http://www.zcars.com.au/images/porsche-911-gt3-cup-s-interior1.jpg
http://image.motortrend.com/f/motor...r1+re0+ar1/porsche-911-gt3-cup-s-interior.jpg
http://www.gotbroken.com/wp-content...997-gt3-cup-cockpit-interior-view-588x441.jpg
