Quote: Originally posted by welsh182 on 16 May 2004
So 2 live, maybe a clio costs more I dont know, but when you have a VW specialist who sells and fits and at one point even made his own flatside sliding throttle bodies which worked perfectly, and has tested, fitted and mapped numerous setups and has numerous maps which may need slight modification to run my engine which is a similar spec to his demonstrator, then does not cost sh*tloads as you put it.
Having spent the best part of 20k modding my car, not bodykitting it, but making it go/stop better, I have no motivation to make up prices for anything
yes mate like i said the r/r bit is the ££££££ consuming part............but if this guy has set up so many of em then he will obviously have a base map to work from hence cuttin down time needed on the rollers
with the renos, because theres a severe lack of em runnin this set up , and those that are have all been done at difrent places, therefore no1 has a base map to work from and has to spend more time on rollers to get the best results......also tunin co.s dont seem to want to help each other so problems raised etc will have to be dealt with individually.....whereas the guy thats doin urs has obviously come up against all the probs before n knows his way round em.......again time=money
