Throttle cable for jenvey ITB's
Car  Cup In bits
I have bought and will be fitting a set Jenvey ITB's fitted to my mk2 soon. I have already bought a phase 1 pedal and throttle cable. The pedal fits with some adjustment but the cable dosent fit into the ITB's in anyway.
I have seen a cable on the jenvey site that will fit in ITB's but how do I connect the other end to the pedal and hold the outer sheath from moving??
I found it easier to chop the throttle body end off the Clio cable and then put a new nipple on the end (mines just a screw clamped jobby) most places sell them as repair nipples
No problems with it in the last year
Cheers for the input Phil, I was going to chop up the standard but after phoning Jenvey this morning they are going to send out a cable with right end for itb's ,bulkhead adaptor, truneon for pedal and other bits to have a play with FOC.
Big up Jenvey, they have been spot on everytime I have called or used them and would recommend to anyone for there customer service & their products ain't too bad aswell :)
Morgan as above just cut the outer off of the phase 1 cable and feed it into the throttle body linkage, if you want a Jenvey cable to use pm me your address and I will post you one as I got 2 with my kit but never used them.
