throttle sticking open
Car  phase 1 172
lately i`ve noticed that my throttle is sticking open and while pulling up at traffic lights etc i have to put my foot under the pedal knock it upwards to get the revs back to normal idle
is this a problem with the cable or the pedal or neither
any advice
cheers
Mine did this it was the cable fraying by the pedal and was getting caught. Check the cable ensure its intact. Maybe get a bit of lube on it if it is
useless ;)
i`l have a butchers and look at the cable mechanism but if i`m not honest not a clue what i`m looking for } )
ICV is on the back of the inlet manifold next to the TB. its black and had VDO on it.
99% sure its a cable though.
check at the pedel end and at the TB.
if its not then clean the ICV with wd40 . its held on bu two torx nuts
cheers ben, if its the cable how easy is it to replace/ fix?
20 min job.
jack up the drivers side,
wheel off
back of the arch liner off
back in the car and unclip the white clip from the pedel
remove the cable through the bulkhead
make note of its path to the TB as if it isnt routed correctly then it will still stick
unclip from the TB (dont loose the steel clip LOL)
re fit in reverse order
sounds simple but i have a special ability to muck things like this up!
where can i get the cable / price?
cheers
meant to ask someone where the cable comes out of the throttle body it goes through a 3 inch plastic cylinder before heading down to the bottom of the bulk head
is this a kind of adjument/ tightening mechanism cuz it appears you can twist it
i maybe talkin utter sh**e tho
LOL well a garage will only charge £30 to fit if not :)
check the cable for fraying first mate (both ends)
i`l check for fraying then, is it normal for the accelerater pedal to be able to lift right up unlike the clutch and brake which only move the one way?
is this a king of adjument/ tightening mechanism cuz it appears you can twist it
yes, it has a clip on it to take up the slack of the cable.
does yours have the steel clip which slots in the grove?
yes thats normal as the cable just flex's its not on a solid mech like the brake and clutch
not sure i`l have a look, do you just twist or is it more complicated than that?
so can i adjust it anyway using the black bit, earlier you mentioned dont remove the steel clip is that the one you were on about
yer, try that too. i ment to say when you remove it.. Do NOT loose it as you can buy them unless you buy a TB for £300 iirc
This is a common problem by the soundsof it as my old phase one did this most annoying and its definately a cable issue.
now your making me nervous ben :)
so just twist ity and it should take the slack out of the cable?
without sounding like a complete dribbler (probably too late there) do i remove the clip before twisting ot leave it?
Look in the guides section M8. I posted a guide to changing the throttle cable recently. It will be the cable that's the cause.
Rob669
Cable would have to be pretty rubbered to cause it to stick open so a quick look will confirm for it fraying.
My guess would be the common ph1 172 problem of the Throttle Body spring becoming baggy.
I'm not convinced that there is a common ph1 172 problem of the Throttle Body spring becoming baggy. I nearly bought a new TB because my revs wouldn't drop down, but then I just changed the cable (it had been changed 3 months before and was fine until I messed about with it) and I carefully routed the new cable behind the bulkhead soundproofing so it felt really smooth. It sorted out the problem and has been fine for a few months now. It saved me £200 quid!:cool:
Cheers, Rob669
The springs does get week over time and a you need to sort it out some people are lucky and don't though.
Rob669
Hi rob
I have just brought a clio 172 sport 2000 plate,well inpressed with her but one problem,"reving to high".Could you help the revs stay at about two k then you blip it and revs go to normal i see you have a way of changing the cable do you have any photos a a guide to do this ? please help.Also you said o go to guides and go to m8 cant find this.fist time on this sight.
very kind regards
jason
email address is chrissieclemett@blueyonder.co.uk
Mine was fraying on my ph1 before so I replaced with a new one and it's spot on now, much smoother. Not that hard to fit in the end.
