Time to change gearbox?
Did mine on my back on the drive on axel stands in about 10 hours on my own. So it recon you can easily shave a few hours off that a with a lift and an extra pair of hands.
I'd personally not bother with the lift if your going to have to pay for it.
It's more than doable on the floor, it's actually possible to lift the box out the top
Sod trying to take it out from the top, would love to see someone do it that way!!!!!!!
On a ramp with two of you 5 hours or so.
My personal best for a change on one with sump guard and skid plate was 2 hours 35 minutes and that was with curry rice and chips thrown in as well ☺
I'm sure @Budgie used to take them out the top.
Pretty sure it was him.
I did it that way as I couldn't be arsed with the subframe bolts spinning.
Was a case of remove basically everything, inlet plenum, ecu etc and there's just enough room to maouver it out.
If I was to do it again id probably drop the subframe as it was a massive pain to be honest.
