Time to spend
Car  clio 182
Hi guys,
my Clio has done 64000 now so time is approaching for cam/aux belt change round 2. Dephaser is definitely on its way out as well so that needs doing. Is there anything else that anyone can recommend I should change at this service interval while it's all apart?!
cheers
Water pump? Someone else will need to confirm this but i've heard that these obviously are easy to change once you have the engine apart when doing the cambelt
Water pump if you want to,crank pulley bolt (only a couple of quid),change the oil & filter if you have the dephaser done,if your rocker cover leaks then now is the time to have that sorted as well (probably an extra hour labour at most places).
Cheers Ross.
Thanks guys. I was thinking water pump for the reasons you said. I've just spend 80 quid on oil that i put In about 100 miles ago. Is oil and filter necessary?
