Clio 182
I was driving from Sheffield down to Surrey, in fairness in a fairly spirited manner. When I hit some of the 50mph average speed sections, when changing the music I noticed a new faint rattle. I thought it was probably the exhaust heatshield, attached to the steering rack which I changed last weekend.
Anyway it's a very minor noise so I continue. Pulling into my parent's town of Cobham, the car feels a little strange, slightly down on power, then about 100 yards from my parents house there is a funny clunking noise followed by the engine cutting out and PAS going dead. So I pull over and try to start it once, but it won't fire. So get my Dad to come tow me the last little bit.
First thing I decided to check in the morning was the timing belt and it looked ok at first. Then we crank the engine and the belt jumps all over the place and goes loose, and a torrent of swear words pour from my mouth.
You can see the loose belt here:
A little bit of plastic jumped out too, which I assume is some part of one of the pulleys.
Looking at the exhausts it looks as though the car was running rich for a good part of the journey as they are very sooty, so the timing had probably started to go off as the belt loosened which would explain the loss of power.
It's a 182 FF, 74k miles. The previous owner had the timing belt done and I even rang him after about 6 months when I was getting the 72k service to double check and be sure I didn't need to get it done. The auxiliary belt and all tensioners, pulleys etc. were done at 72k, so that belt is fine.
I can only guess that when the timing belt was done the pulleys weren't and that one of them has disintegrated. Luckily it only happened at 10mph, not long before that I was going a hell of a lot faster than that!
So will have to get the head off and see what the damage is, but I'd be very lucky not to have contact between valves and pistons.
Garage bills for this will be huge, so more than likely I'll be sorting it myself.
Does anyone in the Sheffield area have the timing belt tools that I could borrow, I can reimburse with crates of beer?!
Also, anyone know a rough price for a 2nd hand 182 engine of a similar mileage, as it may work out easier / cheaper to do that if it's properly nackered?
Gutted. Had literally just sorted the car out after a snow incident in January, new subframe, hub, struts, steering rack etc. Many many weekends crawling about underneath fixing it, then this happens!!!
