Cheers mate, interesting that the vernier's fitted your cams, I was under the impression there was no keyway for them. Trouble is it is not easy to check!
No worries on the timing settings, was a long shot!
I've got a cut up rocker cover here also but that is to allow measuring lift at TDC to set it up, then from there it will have been the verniers that allowed you easy dialing of the cams I think? Otherwise as I understand it you need to untension the belt and slacken off the pulley bolts etc if you want to rotate the cams, regardless of the rocker access.
I 've since spoken to RST though and they have the proper catcams tool so we are just going to use that to make sure the cams are properly timed using a dial guage. I did initialy suggest maybe looking at retarding the exh cam for more overlap but it could make it worse and without the verniers it's just too damn unfeasibly expensive to bugger about testing. So I am going to stick with the corrected default settings which should be a vast improvment over my current settings anyway which are likely quite a bit out from everything I have seen of catcams machining!
If your car had ITB's then it must be the white one thats occasionally mentioned still over on 197! Other than a proper rally car I know it's still the only other mk3 I've seen with ITB's. Hopefully I'll get mine on them before long.
