Timing out on inlet cam
  Clio 182 Trophy
Hi all im after some technical knowledge on the f4r 738 engine. I checked the timing at the weekend as when i purchased the car last year the timing belt had been done before by a local garage, i was a little suspicious that it had been done correctly due to hearing a few things regarding so called garage and on top of that they had just mot'd the vehicle and it had a cv boot gone and the manifold to cat bolts had rotted out and was blowing before the cat. I have been meaning to check timing for ages just never got around to doing it.
On checking timing i found that the inlet cam was ever so slightly out of alignment, i would say its about half a tooth out on the pulley side if that makes sense this could be due to belt stretching mind so i want to firstly know is this going to be an issue and if so as the belt is only a year old and has been changed can i adjust the dephaser bolt by simply undoing and re-torque in the correct position or would it be better to replace the belt and bolts again with new and align everything correctly as per f4r 730 manual.
Im not sure if the dephaser bolt is a stretch bolt hence my question and query so if any technical people who know these cars knows this it would be greatly appreciated.
Liam
  Yozz'd up 182
You need the locking tools to do it properly. Just take it too a specialist. it will save you all kinds of trouble.
  Clio 182 Trophy
I have the locking tools to hand and there genuine renault ones however im kind of wondering if its worth me doing the belt in the first place as im currently looking at doing cams in a few months hence why i want to know if the dephaser bolt is reusable i know its a final torque of 100nm and there is no degrees on top of that so im guessing its not a stretch bolt but if it is it will all need stripping down and doing properly.
Also is it worth doing for half a tooth out?
  Lionel Richie
yeah its fine to reuse the bolt, and yes it'll need re timing properly, not just a case of undoing the bolt and re torque'ing, i bet the cambelt tension is way out, check it
