How do you do this? I tried doing it and failed miserably! It was creasing and all sorts when I tried to push the air bubbles out. It will be the finishing touch to my stealth mobile.
The rear one is impossible mate because of the curvage. Someone I know did it on his Astra, did the rear two and had to pay someone to professionally do his rear as he failed miserably!
it has to be done in 2 strips sometimes 3. you can hide the joins along the heating strip on the window. It's impossible to do with the tint that you can get from halfrauds. you need to get some professional stuff off ebay which is alot easier to work with.
Get an old squirty bottle, fill it with soapy water. Spray the soapy water on the rear window and the tint film. Put it on, push the air bubbles out. Push the air bubbles to the closest edge. Then, as has been said, any you cant push out heat up with a hair dryer
The soapy water will let you move the tint film easily, and wont stop it sticking when it drys
just get a pro to do it, will look so much better. Mine cost me £30 and the film is like £20 from stores so well worth it. Did the side ones myself tho, cause their easier.
