Are they not set to parallel!!?? Caster is not really necessary unless u've got alot of understear, we tend to give the race car 3-5mm toe out in the wet.
Providing that the dealer copied the part of the manual which relates to the Trophy, the settings are toe-out 0.25' +/- 0.17'.
Castor varies with ride height, checking mine it is 2.30' which is the mid point of the schedule.
Camber is negative 0.17' +/- 30'; mine is about 30' with 1.30' on the rear. for track work I feel sure that more front camber will be needed. The Challenge cars run over 3 degrees f&r.
