Could do with some trained ears, I realise its hard to diagnose unless stripping the engine or hearing it in person, basically I thought this clacking type noise in the video below was the water pump bearing failing and after the pump and a new Aux kit was fitted the noise still existed. It will be taken to a specialist asap, Im working at the moment and its a bad time due to tax, MOT due now and insurance next month.
The car drives fine but I'm avoiding driving it now.
Both cam belt kit, aux kit and dephaser where changed a year and a half ago. Can anyone suggest what they think the noise could be? I will take it to a specialist I know of when I have some money set aside, I'd just like to know what needs changing so I can estimate how much this will cost me.
The aux belt was also taken off and the engine ran shortly which showed the noise still being there, so it ruled out any of the pulleys.
Dephaser going again? even after being changed? cams damaged? Seeing as the gearbox diff bearings need changing as well as this Im weighing up my options.
Its quiet from cold, you can hear the tappy clacking noise after 5 seconds on the video.
