Top mount guide
I have done a search for a guide for replacing the top mounts, but I cant find anything. Does anyone know of anything on here? and also would it be the same for the rest of the clios, so I could go and look at a haynes manual?
  Focus rs
I'm pretty sure they are the same. Two bolts hold the bottom of the strut to the hub(18mm). Then undo the top but to remove the shock. You'll then have to get the spring compressed in order to change the top mount.
Re-assemble in reverse.
  Westfield, 182, 200
Pretty sure on 1*2's you don't need a spring compressor.
Also, when you remove the 2 bottom bolts, the hub will drop-be careful you don't pop the CV joints apart.
