Fred, a friend of mine has put a new exhaust on his black 172 and it looks great. It pokes out through the rear valance rather than underneath. I have a picture of it if you post your e-mail address. This is what he did.
He made the rear exhaust fit, which is stainless steel, by shortening the bend which goes over the rear sub frame, so that it comes out of the rear valance. He made up a template and held it on the valance with masking tape and very carefully drilled out the hole.
To get it right on the valance, he first of all cut off the rear silencer and held up the big bore one and marked it at rear of valance, by marking centre and then drilling the hole in centre and then cut and filed to suit. The silencer is now up high and does not get caught on anything, the exhaust shield at the rear was bought from John at D/Tweeks.
The shield at the rear has dummy bolt heads on it but when fitted he drilled through them and put on stainless
steel round allan key nuts and bolts and then painted them black as the shield is aluminium when new.
Dont know if this will help you with your exhaust!
