.Torrent Speed (Azureus)
Having download speed issues, says theres 5000+seeds and as many peers and I'm download at b/s! upto a few kb/s, with 20 odd seeds and peers.
I've allowed for NAT (months ago) in my router settings but it says theres a NAT problem again.
NTL throttling loads of ports?
Anything I can change, share ratio is 0.64, tried resticting upload speed but but no luck.
check firewalls etc , and router setting when i had problems it downloaded at 2k , now im getting 100k easy
I always used to get piss poor speeds with no tracker, until I changed the port to 6969. Amusing, but it flies now, get around 70-80 on most.
mate...i dunno how but i used to always make sure my ratio was wicked...in the end i couldn't be bothered and i still got decent dwonloads. If your getting a nat problem change the port and it should refresh it....but again i noticed even with NAT problms, it would stil work fine.
its a pain at work i have a 2 meg leased line 2Mb up and down perfect for torrents but the downloads are really slow maybe it is just because of th etorrenst im getting but who knows :(
i used to use a small torrent prog, really simple to use and not many options cant remember the name. I opened the ports for my router and set them in the torrent program and it started running pretty good, i think albums and apps etc used to download really fast like at 70-90kb's, but games and movies used to take ages and go at like 30-40kbs.
Now using newsgroups and it max's out every download at around 120kb's each time no matter what.
get usenext ffs, max d/load bandwidth all the time , if you pay.
Its 500kb/sec if you use the free version!
