touque settings
  C63 AMG, F430 & 172
if i dont have a wrench with a degree dail on it,,
the settings are stage 1 20nm
stage 2 180 degrees
stage 3 260 degrees
what would the end torque value be
  C63 AMG, F430 & 172
bet if i start a .. "whats better a 57i with a CAF to my grill or a viper with a CAf to the fog light?"
id get 50 reply's lol
  Clio 172 ph2 + 990SM
hang on, are you trying to imply that theres more bullshitters than mechanics on here? lol
i dont have a clue, but at a guess, it probably depends on the strength of the spring in the torque wrench. got a pic?
you cannot calculate torque values from the angle torque method.
180 deg is 12 o'clock to 6 o'clock.
260 is 10 deg under 12 o'clock to 9 o'clock
if your careful you can eye it, because the reason manufacturers use angle method is that it allows monekys with no clue some rate of success.
