Track Rod and Ball Joint Removal Tools
Car  PH1 172 Sport
Need to remove my track rods this weekend whilst the rack is on the car. Are there any good tools for the job?
Also doing the lower ball joint so what tool do I need for that?
you need a balljoint splitter to make life easier, you use it on both lower baill joint and track rod end apart from that spanners and a rachet set will see you good.
Yea fairly sure it does. If you can try split the gaiter and see, I'd imagine you need to raplace that too!
