track rod ends possibly? help!
Car  02 plate 172 sport
Hi all,
Had my wheel berings done today, However ive still got a bit of movement when the wheel is off the ground.
The mechanic said it was track rod ends that need to be replaced.
Where is the best place to get track rod ends? Anything specific to go for?
Thanks all
Euro Car parts and get Lemforder ones or PM Maynard on here, heres really good he works for GSF.
You might want to have a better look as it seems the inner tie rod ends wear too.
Just check foe exsessive play. Jack it up get someone to wiggle the wheel whilst you have your hand on them lol
Just waiting on the parts to do mine lol
yes it could be between rod end or ball joint. and benn j's advise is right for checking if tie rod end is worn out.
i'm also getting new ones but i have to import them as they are too expensive here in south africa, it cheaper to import them.
