Track set up
Car  Clio 182 cup
What do people think on setting up for the track looking to get spacers,shims and new top mounts .
Top mounts are the ktech solid top mounts
what sort of camber on the rear 2.5 or 3.0 degrees ?
On the front going to go as far as available which is 2.0 degrees.
On the front want to space 20-25mm each side and 10-15mm on the rear each side.
I'm looking for peoples opinions on this set up so fire away please cheers
You need to get on track. Observe how the car handles and how you want it to handle, compare, make a change and test again.
The setup on my Cup is...
FK konigsport coilovers set to firm rear/medium front
Whiteline rear ARB set on hard
3 degrees of camber on the front/going to run 1 degree camber shims in the rear to make 2 degrees-20 minutes
25mm Hubcentric spacers on the front/13mm hubcentric on the rears
Toyo R888's
That seemed to be a pretty capable setup for me as I like more of an oversteery drive, very adjustable on the limit also. Not ever tried solid topmounts, from what i've heard the standard ones are pretty good anyways.
