Tracking and camber
  Clio 172,Vw Bora Tdi
One question ,maybe somebody knows.
I'm going to fit to my 172 spacers on the front and camber bolts, and on the back shims and camber shims,1 degree. And stud and nut kit all around.
This is my weekend / track car, so not a lot of miles done in one year.
Who can do wheel alignment and camber around the Derby or Nottingham area?
Sent from my SM-G950F using Tapatalk
Get it checked before you do the rear.
Yes, it has been suggested to check the rear beforehand. Should I wait until I do the tracking and see what's up with the rear? And then add the spacers or is there a accurate way or measuring it by yourself?
  dan's cast offs.
You can get the front set and just go off the read g they give you for the rear and then shim it.
