Traction Control light doesn't work??
  clio 172 cup
So I've had a look online but cannot find a solution,
My traction control light doesn't illuminate when in use or if I turn the switch off, however it is still working and so is the switch. When I activate the test mode for the dials it light's up.
Any ideas?
Thanks in advance. Kirk.
Do you need it to illuminate in use?
If it passes the MOT test, the system is working and you can tell it's working without the light, is it an issue??
