Traction control?
Basically guys my 172 has a button for traction control, when I press the button nothing happens! By that I mean no lights come up on the dash to inform me whether its on or off, is this right or does that mean traction control is broken?
traction control was 03 onwords, do you have a Y plate - 52 plate? possibly had a new pannel at some point with the button.
also as above check to see if its plugged in
It could be the plug being disconnected, yes.
Although thinking about it - if it was disconnected it might bring up the ESP and SERV lights, although don't quote me on that.
What reg is your jam jar?
I have a cup, so no experience but in most cars you have to hold the button to turn it off. Is this not the case with the clio?
My 52 plate FF has it.
Doesn't have cruise though. I thought all the PH2 had Traction but Cruise was 53>?
I may be wrong though!
A light with a car swerving should come up on the dash when you press it.. The same light should flash when you try and spin the wheels.. Do all the other dash lights work??
